Loading...
Valve Index
Pros
headpone is adjustable
and does not touch your ears
3D audio
manual IPD adjustment between 58 and 70 mm
personally think this is annoying..
it has a usb 3 port in front of the headset, so can add custom modules
(eg.
leap motion, smell accessories)
Display: 1600 x 1440 LCD
same as vive pro
(but
with OLED), better than rift s
LCD display for resuced screen door effect
fill factor 3x greater than OLED
LCD produces 50% more subpixels then OLED, more sharpness with the same rendering cost
120 Hz & experimental 144 Hz
(has
options 80, 90, 120, 144)
usual VR headset is 90 Hz
decrease motion sickness
help increase your score in games XDD
has pluggable cushin for the headset, so kids with smaller heads can play
can also make your own
(3D
print) customized cushin and plug into the headset
the controller has a touch sensitive button with haptics feedback
not much distortion compared to pimax
no breakout box, a single cable splits at the end and can be connected to pc separately
the gasket of the headset
(the
cushin in front) is magnetic so easy to plug in and out
can adjust closeness of the hmd to the eye
(tho
moving near sacrifices fov
the mic is really good
Cons
Need a graphics card with display port, cause it’s not using HDMI
this is to achieve higher resolution and refresh rate
Need a portable backpack PC or very long cables
have hand tracking sensors on controllers but game developers will have to integrate it manually
(not
come automatically)
all things are not wireless
need to adjust your hands for the controller to sense the correct hand pose
weight of the headset may let some users pitch forward
(heavy)
make the screen not clear
has god rays
but can be solved by adjusting headset position and find a sweet spot
Facts
strap is similar to vive pro
two forward facing cameras for pass-through video
(can
see the real world when using VR
works with 1.0 and 2.0 lighthouse
~1000 USD
controller light color meaning
when plugged in
white: fully charged
orange: still charging
green: paired and tracking
when not
blue: powered but not paired
flashing light: low battery / error
off: no power
Please turn on JavaScript to use Paper in all of its awesomeness. ^_^
Pros
Cons
Facts
