Open the plugins folder of your Unreal Engine installation for example“D:\Program Files\Epic Games\UE_5.0\Engine\Plugins”
Extract ConnecterUEPlugin_0.9.2_5.0.zip directly into this directory. After that you should see a folder named Connecter.
NOTE: It’s impossible to differentiate the Preview versions. That’s why we can’t offer an automatic installation from within Connecter. Until an official version is released, you should install the integrations manually.
version: v.0.9.2
date: March 2nd, 2022
Bug fixes
Fixed: Encoding issue affecting paths including Chinese characters.
version: v.0.9.1
date: October 14th, 2021
Supported Unreal Engine versions
Added: Support for 5.0 Early Access - only available through the Manual install option(you have to point the folder where UE5 is installed)
NOTE: As UE5 continues to be developed, we may not be able to catch up with the development. Full, stable support will be available when a official version of Unreal Engine 5 is released.
Support for Unreal Engine Preview releases
Bug fixes
