Loading...
Topo Kit Component Reference
CAMPUS
Topo
Kit
Use the table of contents to the left
(the
tick marks) or
CTRL F
to find what you are looking for.
Red Dots indicate pro components.
Â
Â
Â
Â
+curbCUT
add curb cuts
Adds curb cuts to collection of curbs from curb cut centerlines. Also returns ramp features.
INPUTS
<C>
: Collection of Curb instances to add curb cuts to
cut_cls
: Centerlines of curb cuts
width
: Width of main ramp
run
: Run distance of main ramp
flare
: Width of each side of the flare
OUTPUTS
curbs
: Curbs with added cuts
ramps
: Ramp objects to add to your topo
preview
: Preview of the new ramp outlines
Â
Â
Â
Â
GT+x
add to geo set
Adds geometry to specific categories of a geo set for topo. ie contour curves, spots, etc
INPUTS
geo_set
: Existing geo set for topo. Will make a new one if nothing is input here.
contour_curves
: Contours as elevated curves. Open is okay, tiny polyline segments may be bad.
spots
: Spots as elevated points.
breaklines
: Curves. Similar implementation as the contours, with some subtle differences.
other_geo
: Meshes or Breps that describe a topo zone.
mendlines
: Curves drawn between contours that will help reduce sawtooth meshing at steep grades. Use sparingly
boundaries
: Curve boundary of the areas being created or modified.
OUTPUTS
<GT>
: Geo Set with your additional geometries
Â
Â
Â
Â
+AREA
create area
Creates an area class, a material zone, described as a mesh, trimmed surface, or closed curve.
INPUTS
geometry
: plan area as defined as a flat closed curve or trimmed surface
dist_tol
: distance tolerance for creating a mesh - default .01
edge_tol
: edge tolerance for creating a mesh - default 5
layer
: name of the layer the area should be part of
color
: area color
OUTPUTS
<A>
: Area Instance
mesh
: flat meshes
Please turn on JavaScript to use Spaces in all of its awesomeness. ^_^
+curbCUT
GT+x
+AREA
