Plant Kit FAQ’s
- Installation
- Q: What are all the plug-ins that need to be installed for Plant Kit to run properly?
- Setting up an Environment
- Q: How do I define areas? And why are areas so important?
- Q: How do I integrate multiple meshes into one environment?
- Q: How can I define solar and light conditions specific to the location of my site?
- Changing Planting Mix Parameters
- Q: How do I add new plants to the plant list?
- Q: How do I adjust the number of plants in a pseudo planting mix?
- Q: Can I restrict which plants from the plant library are selected for planting iterations?
- Q: What does it mean to pack plants? What is a packing ratio?
- Q: Can I restrict species selected from the plant library to a specific planting zone or ecoregion?
- Q: Can I create a planting scenario that holds the species the same, but factors in changes to their growth radius and likelihood of viability over time?
- Introducing Customization within Planting Mixes
- Q: How do feature proximities influence planting designs?
- Q: Can I integrate cartesian geometry into Plant Kit?
- Q: Can I integrate attractor points for plants within an area?
- Defining niches
- Q: How do I isolate hillsides orientations or specific slopes to define a planting niche?
- Q: What is a planting niche?
- Exporting Designs
- Q: How do I export a planting design into Revit?
- Data Sources + Data Management
- Q: Where does the data from the plant library come from?
- Q: I’m developing a planting plan for a vast landscape. What techniques and data management practices should I follow for maximum processing speed?
- LANDAU Design+Technology
​​Installation
​​Setting up an Environment
​​Changing Planting Mix Parameters
​​Introducing Customization within Planting Mixes
​​Defining niches
​​Exporting Designs
​​Data Sources + Data Management
