PerfectReal RealEstate Management Application - Cross platform with .NET MVC Admin
PerfectReal is a cross-platform application for Real Estate Agencies to manage their properties listing, built on Xamarin Forms. It supports both iOS & Android.  PerfectReal helps you build a supportive sales property, easily customizable according to your needs. The interface is designed modern, beautiful. Data is connected via the RESTful API, allowing easy connection to your existing systems. We are committed to supporting you the best
Created: 3/07/2019
Latest update: 04/07/2019
By: TLS Software
Support Skype/Email : thanhlongsolutions4u@gmail.com
Web App Installation Guide
Requirements: ASP.NET MVC 5, SQL Server 2008 R2 +, IIS8+
There are a few steps for a quick installation:
  • 1. Using file in forder /database/db_RealEstateManagementEvanto.bak to restore database, create database user and grant all permission to user for this database.
  • 2.Open the LinkPublish folder
  • 3.Open /link publish/web/Web.config file and change the following tags: connectionString="metadata=res://*/Models.Db.csdl|res://*/Models.Db.ssdl|res://*/Models.Db.msl;provider=System.Data.SqlClient;provider connection string="data source=YOUR-SQLSERVERNAME;initial catalog=YourDatabaseName;persist security info=True;user id=DATABASE-USER;password=DATABASE-PASSWORD;MultipleActiveResultSets=True;App=EntityFramework"" providerName="System.Data.EntityClient"
  • ConnectionStrings tag as below:
  • i.data source: your server name
  • ii.catalog: your database name
  • iii.id: your username
  • iv.password: your password
  • 4.Install IIS in your server machine
  • 5.Paste /link publish/web/ project In IIS wwwroot directory
  • 6.Install ASP.NET Core hosting bundle for Windows (with correct version);
  • 7.Create a new web site in the IIS and target the published files; and
  • 8.Run the app
API Installation Guide
There are a few steps for a quick installation :
  • 3.Open /link publish/api/Web.config file and change the following tags:connectionString="metadata=res://*/DAL.RealEstate.csdl|res://*/DAL.RealEstate.ssdl|res://*/DAL.RealEstate.msl;provider=System.Data.SqlClient;provider connection string="data source=YOUR-SQLSERVERNAME;initial catalog=YOUR-DATABASENAME;user id=YOUR-DATABASEUSER;password=YOUR-DATABASE-PASSWORD;multipleactiveresultsets=True;application name=EntityFramework"" providerName="System.Data.EntityClient"
  • 5.Paste /link publish/api/ project In IIS wwwroot directory
  • 8.Run the app
  • Links can help you:
Mobile App Installation Guide
