Loading...
Paving Kit Component Reference
CAMPUS
Paving
Kit
Use the table of contents to the left
(the
tick marks) or
CTRL F
to find what you are looking for.
Red Dots indicate pro components.
Â
Â
Â
Â
+CR
add color rule
Add paving color rule to an area
INPUTS
<A>
: Area to add color rule to
<C>
: Color rule
(as
list)
OUTPUTS
<A>
: Area with added color rule
Â
Â
Â
Â
+CPAT
add custom pattern
Add custom paver shapes as curves to an area
INPUTS
<A>
: Area to add custom pavers to
pavers
: paver_curves
OUTPUTS
<A>
: Area with custom pattern added
Â
Â
Â
Â
+PAT
add pattern to area
Add a paving pattern to an area
INPUTS
<A>
: Area to add paving to. Paving will replace existing paving.
pattern
: Index of pattern - 0-Grid, 1-RunningBond, 2-Hex, 3-Tri, 4-HerringBone, 5-Radial
POB
: Point of beginning for each area
length
: Dimension of first or primary side
width
: Dimension of second or secondary side
steps
: Number of steps if required
(like
in Running Bond or Herringbone)
seam
: Size of seam in inches. Larger seam will not cut into paver dimensions.
rotation
: Number of degrees rotate the pattern
OUTPUTS
<A>
: Area with pavers added
(replaced)
pavers
: paver shapes
Â
Â
Â
Â
+TEXTURE
add paver texture
Adds a randomly scaled texture to paver meshes within given scale range. Best with square images.
INPUTS
paver meshes
: meshes describing pavers
min scale
: minimum random scaling
Please turn on JavaScript to use Paper in all of its awesomeness. ^_^
+CR
+CPAT
+PAT
+TEXTURE
