Module system examples
futures-rs
Public surface
Several submodules, no nesting within them
Several type definitions and re-exports
Internal surface
many nested modules for file organization and namespacing
generally each provides one or two definitions that are re-exported by the parent
regex
Public surface
Almost entirely flat, except
bytes
submodule
(which
is like an entire alternative API surface)
Internal surface
flat
seemingly mostly for file organization
some use of privacy
rayon
Public surface
Quite a few submodules, with further nesting within them
The nested submodules are very small — most define
Iter
and
IntoIter
for particular types
These definitions would not need to be exposed if we had
impl Trait
in trait impls
Could also just re-organize these into a single submodule
Several functions and types defined at top level
Internal surface
Many public submodules are just files
These are mixed with files that do
not
define public submodules, making it difficult to discern the module structure
This seems to come down to the
impl Trait
issue above
test.rs
at root level
log
Public surface
No submodules
Internal surface
Just one file
openssl
Public surface
Many
submodules at root, no nesting
Only one function at top level
Internal surface
Mostly flat list of files
Most
correspond to public submodules, but some do not
flate2
Public surface
A few submodules, each of which contains a bunch of types
Several definitions at top level
Internal surface
Directory/file structure doesn’t match public API surface at all
Please turn on JavaScript to use Paper in all of its awesomeness. ^_^
