Microphones manual
This covers how to make microphones from scratch. They are suitable for use in streamboxes and other applications.
[See eg Streambox manual May 2023
Many thanks for images to Lia Mazzari https://liamazzari.com/
Buy microphones
Micbooster make microphones based on the excellent Primo capsules. They have the best quality for the cost available, we think.
You can also buy microphones from us.
contact@soundtent.org
grant@soundtent.org
We use very good cable and connectors, which may make our microphones more resistant to EMI. This can be relevant for broadcasting / streaming.  Our microphones (and streamboxes) come with an indefinite commitment to replace, repair and/or help with any issues you encounter.
Parts and suppliers
MICROPHONES
The Primo EM272Z replaces the legendary Primo EM172! They seem just as good. The PUI is a cheaper alternative, which gives more tolerance for learning. They also sound excellent, and work particularly well with the IQ Audio Codec Zero for running live streams – maybe better than the Primo’s. Otherwise, they may lack some detail and refinement, but opinions vary.
  • Microphone capsules x 2
  • Primo Primo EM272Z1 Omni Electret Condenser from micbooster
  • OR
  • PUI AOM-5024L-HD-R electret condenser from Mouser
  • Microphone cable about 30 cm for streamboxes [or longer eg 1m for general field recording] eg:
  • OR
  • [ALT for XLR
  • Connectors
  • Hi-con stereo minijack (our preference. has a wide hole to accommodate 2 shielded cables. Less easy to find. Different soldering configuration. Possibly easier to solder than the more common Neutriks: https://www.thomann.de/gb/hicon_hij35s02.htm
  • Neutrik stereo minijack — various. Check they will accommodate the stereo cable you are using.
WINDSCREEN
  • small foam windscreens eg
