LingualBox has a transparent rule for deciding the rate and salary.
LingualBox Salary System:
At LingualBox, the salary will be determined by 3 things.
Base Hourly Rate
Adjustment of Hourly Rate
One Time Penalties
Base Hourly Rate
At LingualBox, we believe being fair is important. So, we apply the following system to all the tutors.
Less than 1 year of experience: 120PHP/hour
Less than 1 year of experience with(English major or TESOL: 135PHP/hour
Less than 3 years of experience: 125PHP/hour
Less than 3 years of experience with English Major or TESOL: 140PHP/hour
Less than 5 years of experience: 130PHP/hour
Less than 5 years of experience with English Major or TESOL: 145PHP/hour
More than 5 years of experience: 135PHP/hour
More than 5 years of experience with English Major or TESOL: 150PHP/hour
More than 8 years of experience: 140PHP/hour
More than 8 years of experience with English Major or TESOL: 155PHP/hour
Graveyard Shift: +10PHP
Undergrad:-10PHP
Veteran
After 1500 classes, you are treated as a veteran tutor and your rate will be increased by 10PHP.
Number of open slots
We calculate the number of open slots of the last eight weeks every time we calculate the salary on the salary day. You can calculate the amount of opened slots by this formula.
The number of regular slots + Newly opened slots - Newly closed slots
Less than 10 hours(20 slots)/week :-10PHP
Less than 20 hours(40 slots)/week :-5PHP
20 hours to 34.5 hours: +0PHP
More than 35 hours(70 slots)/week ; +5PHP
Tutor-related issue rate(To be applied after Jul 22, 2019)
On the salary day, we calculate the tutor-related issue rate of the last three months, and we add or reduce the hourly rate based on the result. If a tutor hasn't worked at LingualBox for more than one month, this rule will not be applied. If you have internet issue, we advise you to close the slots immediately so that your issue rate would not climb up.
Base Hourly Rate
Veteran
Tutor-related issue rate (To be applied after Jul 22, 2019)
