In this lab we’ll explore an array-based implementation of a ring buffer(or circular buffer). Ring buffers are used for many things like producer/consumer tasks, computing moving averages, log files, and in this lab, simulating sound waves.
Be sure to read the pages 147–151 from Chapter 1 of the Intro to CS by the authors of our textbook.
Your ring buffer implementation should use an array(not a queue) as its underlying instance variable. The Algorithms book’s ResizingArrayQueue is a good starting place.
Employ the testing based approach we learned last week. Use assertions to check pre- and post-conditions and in-variants whenever you can. Before worrying about GuitarString create a main method in RingBuffer that acts as a simple, straight-forward client exercising all of RingBuffer's methods. You might also add a display method to RingBuffer that prints out its contents.
Modifications:
Your RingBuffer should only throw an exception if you dequeue an empty buffer, if you try and enqueue a full buffer you should just overwrite the oldest entry.
Make RingBuffer generic(i.e., A RingBuffer of Double for GuitarString, but any type in general).
RingBuffer<Double> ringbuffer = new RingBuffer<Double>(3.0);
The second constructor in GuitarString is not necessary: GuitarString(double[] init)
Submit a zip file that expands to a folder with the following files:
cmsc201-lab3-lastname-firstname
README.md [names, emails, date, lab title, and collaboration statement]
RingBuffer.java
GuitarString.java
GuitarHero.java
Reminder that any outside resources in completing the lab should be included in the collaboration statements: names of drop-in tutors, links to websites or stack overflow articles, etc.
Anything that isn’t the textbook, its website, the instructors or dedicated class tutors.
Modifications:
Submission
RingBuffer.java
GuitarString.java
GuitarHero.java
BONUS
for (double d: ringbuffer){
StdOut.println(d);
