Lab 3: Ring Buffers and Guitar Strings
Bard College – Computer Science – Data Structures
In this lab we’ll explore an array-based implementation of a ring (or circular) buffer. Ring buffers are used for many things like producer/consumer tasks, computing moving averages, log files, and in this lab, simulating sound waves. We will follow our textbook authors’ project pretty closely: http://introcs.cs.princeton.edu/java/assignments/guitar.html
Employ the testing based approach we learned last week.
Modifications:
  1. The RingBuffer class should be generic (i.e., ring buffers of Doubles, but also any type).
 RingBuffer<Double> ringbuffer = new RingBuffer<Double>(3);
  1. The RingBuffer should only throw an exception if you dequeue an empty buffer, if you try and enqueue a full buffer you should just overwrite the oldest entry.
 ringbuffer.enqueue(2)
 ringbuffer.enqueue(3)
 ringbuffer.enqueue(5)
 ringbuffer.enqueue(7)
 ringbuffer.enqueue(11)
  1. The second constructor in GuitarString is not necessary.  GuitarString(double[] init)
Extra
  1. Implement an Iterator for your RingBuffer .
 for (double d: ringbuffer){
     StdOut.println(d);
Lab 3 Unit Test (Checklist)
  • Did I format the code properly (tabs & braces)?
  • Did I use an array in my implementation of Ring Buffer?
  • Is my ring buffer generic?
  • Did I test all the ring buffers methods?
  • Does it sound correct?
  • Did I zip & submit .java files (not .class files)?
