Essay Prep: Body Paragraphs
Purpose 🎯
This task is designed to help you better understand the topic, strengthen your critical thinking, and your ability to translate that thinking into a persuasive written form.
Task Description ✏️
Building on the Essay Prep: Academic Sources and Essay Prep: Introduction tasks, you must:
  • Prepare 3 body paragraphs that would form a part of a full essay response to the question asked in relation to the image you have chosen:
  • Be sure you have all the elements of an academic paragraph
  • Ensure that your paragraphs are logically and consistent with your thesis statement
  • Include relevant academic sources and correct referencing
Essay Prompts 🔎
  • Write the essay prompt here
Additional Information 📚
To help you complete this task successfully, the following resources are provided:
  • Marking Rubric — refer to this to understand how you will be assessed
  • Checklist: How to complete this activity — use this to help you complete the task
Checklist: How to complete this activity ✅
Copy and paste this checklist into your Notes. Check off each step as you complete it.
Step 1: Task Understanding
  • Read the Instructions and Checklist carefully
  • Read the Marking Rubric carefully
  • Copy + paste your introductory paragraph into Cadmus — you will build on it through this task
Step 2: Plan Body
  • Use this structure to help you plan your Body (using dot points):
  • Body Paragraphs: this is where you develop your argument and analysis. Add a paragraph for each main idea or theme, including:
  • Topic sentence stating the main theme or idea
  • Sentences elaborating on each theme or idea with supporting evidence and examples
  • Tip: your Essay’s argument will emerge from and demonstrates your critical reading and needs to incorporate evidence from your readings.
  • Concluding sentence summarising the points, linking to the next paragraph/argument
  • Reference List:
  • Include a list of all references you cited
Step 3: First Draft
  • Building on your plan/dot points write your first draft, focusing on the structure
  • Once finished, use this Editing Checklist to review your Body Paragraphs:
  • Body Paragraphs:
  • Does each paragraph have one main idea or theme?
  • Do all the sentences contribute to the main idea or theme?
  • Are the points you make in a logical order?
  • Do the paragraphs connect with each other?
  • Is your argument consistent?Â
