To help you complete your Creative Project, you are required to write a Creative Project Plan, this is where you will set an aim for your Creative Project and also outline a plan for achieving this. Through this task you will develop your goal setting,planning and design skills.Â
Your Creative Project may take any form, e.g. posters, video, design, prototypes, performance, sculpture, music, etc.
Task Description ✏️Â
Write a Creative Project Plan for your intended creative project. As part of this, you will:Â
Summarise what you aim to accomplish and your plan to achieve this.
Include a timeline indicating what you intend to achieve week by week and how you will document this.
Source and document and a minimum of four relevant academic sources to help you research your project.Â
Additional Information đź“šÂ
To help you complete this task successfully, the following resources are provided:
Marking Rubric — refer to this to understand how you will be assessed
Checklist: How to write a Creative Project Plan — use this to help you complete the task
Example: Creative Project Plan — review this to see a completed example of the task
Checklist: How to write a Creative Project Plan âś…Â
Copy and paste this checklist into your Notes. Check off each step as you complete it.
Step 1: Task Understanding
Read the instructions and this checklist carefullyÂ
Read the Marking Rubric carefully
Step 2: Research Project
To help you define the scope of your creative project, you must complete research:Â
Reading the Library Search Tips guide
Identify a set of potentially useful resources
Survey, skim, and scan to find the relevant articles, and parts of articles
Step 4: Critical Reading
As you read the resource, jot down notes using this framework(adapted from Marshall and Rowland(2006)):
The author’s purpose: why has the author written the material? Are these purposes explicitly stated? Are these implicitly stated?
The author’s approach: what are the author’s underlying assumptions? Are these explicitly stated? Is there any proof of bias?Â
Content: what is the author’s thesis? How do they develop the thesis? What evidence, examples, or explanations are used?
Tip: as you read, make reference notes of any sources
Step 3: Define Scope
Based on your research, outline what your creative project is, but also what it isn’t
Tip: this will help you stay focused and avoid“scope creep” later on
Step 4: Write Plan
Use this structure to help you write your Creative Project Plan
Project Summary: provide a high-level understanding of what the project is
Target Audience: state who you want to reach, ie. demographic outline or certain persona
Problem: state the problem that you are trying to solve, explaining why you need to do this
Goal: state why you are doing this project and what you are trying to achieve
Process: outline the steps required and how you will document each part
Purpose 🎯Â
